Rear shock bolts
Old Aug 28, 2013 | 12:46 PM
nrvous's Avatar
Car: 89 formula, 13.5@105 n/a
Engine: 350 hsr, patriot heads, short tubes
Transmission: 700r4 w/shift kit
Axle/Gears: 9" 3.89 Detroit Locker
Rear shock bolts
I just put a Ford 9" in my '89 firebird. It did not come with the lower shock bolts/mounts. I just tried to order through my local Chevy dealer with no luck. Does anyone know of a source to get these new? Yes, I could use a normal bolt to attach, but I figure GM designed these for a reason. Btw the car didn't have a rear-end in it so I can't salvage the used hardware from that. I would like to use new hardware after spending all the money on the diff anyway. Thanks in advance.
Old Aug 28, 2013 | 09:22 PM
Re: Rear shock bolts
About every car made with shock brackets of that sort (A bodies, G bodies, B bodies, etc.) uses the same hardware.
Hit yer local buzzard.
Wire-brush it and paint it black, or even gold, if "new" is really that important to you. It's not like it "wears out" or anything. There's a time and a place for "new", for sure; that ain't it.
Old Aug 28, 2013 | 10:04 PM
SkyHook's Avatar
Car: 1984 "Creamed" Camaro Z28
Transmission: Borg Warner T5 5 Speed
Axle/Gears: '91 Iroc Rearend with 410 gears
New bolts should come with new shocks, Monroe Matics ran me $48 a piece here in Hamilton.
As much as a dealer will try to charge you for a couple bolts you might as well get new shocks.
Old Aug 29, 2013 | 05:23 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Dorman sells them in the "Help!" line... a few bucks a piece..
Old Aug 31, 2013 | 09:25 AM
nrvous's Avatar
thanks for the help. I just purchased a cheap pair of shocks (40 for the pair) and used the hardware. beats rooting around in the dirt at the boneyard.
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
LT1Formula
Nov 16, 2015 01:13 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
