Smoother Ride
Car: 1992 Pontiac Trans Am GTA
Transmission: 5 speed
Smoother Ride
Ever since I bought my car in April of 2012, I can feel every little thing in the road. Does anybody have any ideas on how to make a smoother ride? Shocks maybe? I'm not very experienced with suspension components. I know I do need new sway bar bushings though.
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Smoother Ride
Struts and shocks will be the biggest improvement. Old tires tend to ride stiffer as well.
Car: 92 camaro convertible z28
Transmission: Swapped from 700R4 to T5
Axle/Gears: Stock Posi. Ratio is not known
Re: Smoother Ride
I think bushings are also important.
There are rubber, poly, and derlin bushings out there,
but for a smooth and soft ride rubber ones are the best.
IMO front A arm bushings have a great influence on the ride.
Re: Smoother Ride
I know I need to get new shocks, I'll look into struts as well. The tires are newer so I'll rule out the tires. I'll make a list of all the bushings I think will need replaces. Thanks guys.
Car: 1987 IROC
Engine: 5.7 TPI
Axle/Gears: 9 bolt 3.27s
Re: Smoother Ride
I had the same problem with my '87 IROC and I read somewhere "if you want a good smooth ride...dont buy a sports car"..Ya know..It rides pretty good now..
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Smoother Ride
Rear control arms made a big difference for me as well.
Set a budget, buy the best shocks and struts you can afford. New stock moog springs, new a arm bushings, strut mounts, replace rear control arms with aftermarket. A new ta bushing as well.
Car will feel light years better.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: Smoother Ride
Keep in mind that tires make a huge difference in ride quality - 15" all seasons will ride much better than an 18" summer street tire.
But also realize that changing suspension parts can also have a huge effect on ride quality. I noticed a drop in RQ when moving from stock rubber to poly swaybar bushings and endlinks on my Camaro over 20 years ago. Other items improved ride quality - subframe connectors and an STB make my car ride a bit better, plus it had no rattles of squeaks too.
Re: Smoother Ride
I plan on putting sub frame connectors on after I graduate from college and start building a powerhouse for it. So a change of bushings, struts, and shocks should have me riding pretty smooth?
blackz281le
Jan 11, 2016 07:51 AM
Linson
Sep 21, 2015 01:08 PM
