Rear end setting low?
Car: 92 camaro RS
Engine: 305 TBI
i put new shocks and srpings in and it sits the same and i have 295/50/15R tires on my rear. when i get a good bump my tires hit. what can i do to make the rear end sit higher or his there a different spring i can get thats stronger and gives me a bigger rid hight
Re: Rear end setting low?
You can also add rubber isolators.
Car: 92 camaro RS
Engine: 305 TBI
http://www.rockauto.com/catalog/more...211&cc=1035818 this are the one i just put in
Those springs basically restore the car to stock height. Put it back where it belongs.
Springs aren't your problem.
Sounds like your concern should maybe be with the misfit tires. You don't mention it, but I'd suspect there's some misfit wheels to go along with it.
What happens when the right size tires and wheels are on it?
any way i can get the rear to sit higher
A better plan would be to put wheels and tires on the car THAT FIT.
TRUTH- I also have centerlies with exactly the same 295/50/15's The previous owner put a Replicar Fiberglass Kit onand it weighs down the ar soooo much that he had to put AIR SHOCKS in. The AS does the job of raising the rear wheel wells but not sure I like the ride. ROUGH - see my other thread on this----- I am thinking of taking some air out of the rear tires from 26- down to 22 lbs. To help with ride. and dont go over 35 lbs of air in the Air Shocks "AS". May switch to a beafier set of COILS from GM as a replacement. Keep in touch.
Car: 92 camaro RS
Engine: 305 TBI
I hear aPal--- Boy O Boy do I hear ya.
Car: 92 camaro RS
Engine: 305 TBI
all i want to know is there a different spring that is more heavy duty then the stock ones that will sit a little higher or stiffen it up more thank you
I plan on taking my Tank to a Metal Reclaimation yard and ask to have my Tank weighed. Front End-- Rear End and total weight to know EXACTLY what kind of COILS my Tank needs. I think Im probably 500-750 heavier than the stock weight of an 84 Trans Am. Its a Replicar Ferrari 512 . Good luck.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
novaderrik
Aug 10, 2015 12:44 PM
