GC Weight Jacks & other suspension mods
Old Nov 3, 2013 | 01:50 AM
3rdgensilverRS's Avatar
Car: 1989 Camaro & 2005 Silverado
Engine: 305 TBI & 5.3 Vortec
Transmission: 700R-4
Going to run the GC weightjacks with KYB shocks and struts, QA1 panhard bar, QA1 LCAs, Spohn LCA relocation brackets, Spohn torque arm, & weld in subframe connectors. Car is going to see more street than track anything I need to know about spring rates for street use? Should I just get Eibach Sportlines with all other aftermarket suspension mods? I've read about GC weight jacks and how it's a autoX application I just want adjustability.
Old Nov 3, 2013 | 12:46 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: GC Weight Jacks & other suspension mods
I have CG fr/Rr.I forget the spring rates, but they are not much higher than stock ratings.Something like 600 fr & 170" lbs Rr, both eibach.CG was recommending higher rates over 700 fr.Been there before though.Other susp mods in sig.
Old Nov 3, 2013 | 12:52 PM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
I'm running GC F: 850# R: 225# , but I'm a "MAX effort" street / track ride.
Rethink your shock choice !!!
Old Nov 3, 2013 | 01:44 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
800fronts and 150 or 175 rear work well but yes, seriously look into better shocks
fbodyfreakls1
Oct 6, 2015 06:34 PM
Fox118
Sep 12, 2015 09:29 PM
John in RI
Car Audio
Sep 10, 2015 11:24 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
