Bump stops
Old Nov 4, 2013 | 12:00 AM
rs_gera's Avatar
Car: 1992 Camaro RS 25th Anniversary
Transmission: WCT5
Axle/Gears: 3.42 posi ��
Bump stops
I will be installing eibach Sport lines soon but my bump stops are totally worn out , which are some good replacements .I've seen a lot but don't have the same shape and say they're "universal" would those be ok?
Old Nov 4, 2013 | 06:44 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Bump stops
Originally Posted by rs_gera
I will be installing eibach Sport lines soon but my bump stops are totally worn out , which are some good replacements.
OE rubber replacements are available from such places as RockAuto. You might also check at an auto parts stores.
JamesC
Old Nov 4, 2013 | 10:06 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Bump stops
Also, depending on how much the car is really lowered you may need/want to cut the stops down some (but keep the same profile) to keep more of the range of movement without hitting the stops all the time.
Old Nov 7, 2013 | 12:25 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Re: Bump stops
The fourth gen z28, not SS rear bumpstops are a foam type and would be a worthwhile upgrade.
Up front you can use a shaft mounted bumpstop from ground control. I'd still cut them down but you can regain quite a bit of travel that way.
Ed1LE
Sep 30, 2018 09:14 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
sjorgens
Oct 1, 2015 07:54 PM
Luigytico09
Oct 1, 2015 08:46 AM
1HotZ28&SS
Sep 28, 2015 08:58 PM
