Torque arm clearance
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
I have a quick performance rear in my car with Wolfe adjustable spring perches. My problem is the torque arm bracket hits the tunnel when the suspension compresses. My plan is to raise the tunnel for clearance. Just wondering if anyone else has had this problem. Car has 15x10 wheels with 6.5 back spacing and 28x11.5 et streets on it. Pick shows where I am trying to set ride height.
Re: Torque arm clearance
Couldn't say about that particular combo; but LOTS of aftermarket rear/TA combos have a similar problem. (btdtgtts)
Best plan would be to simply look at where there's clearance issues, examine the surrounding carefully both inside and underneath the car, and make delicate and finely-tuned calibrated optimizations with about a 20-lb BFH.
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
I understand allot of them hit the side of the tunnel but mine hits the top. Like bfh is not going to be enough.
Car: 1984 Trans Am
Engine: 355
Axle/Gears: 10 Bolt, Torsen Diff, 3.73's
You know what they say...when in doubt get a bigger...you know...hammer.
In all seriousness, it should clearance itself before too long. You may have to deal with some banging for a little while, but eventually you should be fine.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
If it hits the top you cant do much aboit it except cut the floor and make some room. Or you have to raise the ride height to compensate.
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Raising ride height would be the easiest solution. But when ride height goes up coolness goes down. In all seriousness I think I am going to cut up the floor.
Car: 18 chevys,2 beaumonts,and a vw beet
Engine: 283,305,327,350,383,396,400,427,468
Transmission: m21,m20,m22,powerglide,turbo350
Axle/Gears: lots
don't cut it up what do you think it is a mustang or something.
all you will do is end up perched on every speed bump and it will drive like a shopping cart
all you will do is end up perched on every speed bump and it will drive like a shopping cart Trending Topics
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Well since its more of a race car and has mini tubs, cut up core support, motor plate i am not to worried about cutting it up.
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
luvofjah
Sep 26, 2015 08:28 PM
Ragtop Man
Sep 12, 2015 12:23 AM
