Strange steering noise?
Old Nov 17, 2013 | 07:59 PM
MeanFbirdT/A's Avatar
Car: 1984 Pontiac Firebird S/E
Engine: LG4 305
Transmission: Borg-Warner T5
Hey guys, I have an 84' Firebird Formula and when I go to full steering lock either way it makes a horrible squealing noise but it doesn't sound like a belt... Has anyone ever had this happen to them?
Old Nov 17, 2013 | 08:54 PM
Re: Strange steering noise?
What happened when you TIGHTENED THE BELT? (as I'm like SO SURE you already did? )
Old Nov 17, 2013 | 09:24 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
PS pump, check the fluid level.
Might have air in the line too.
Old Nov 17, 2013 | 09:42 PM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
mine did that forever. then one day my pump locked up after the pitman arm seal blew out the bottom of the steering box and i had to replace both, both lines, and new belt/fluid. tighten the belt as mentioned. add fluid. "flush" the pump if you can. then add new fluid
Old Nov 18, 2013 | 06:21 AM
Engine: LG4 305
I didn't actually do anything to the belt at all, left it alone. I figured I'd ask before I did anything.
db057
Jan 10, 2020 08:55 PM
BWilcox
Sep 20, 2015 12:19 PM
punkmaster98
Sep 8, 2015 09:45 PM
Randomtask2
Sep 7, 2015 05:06 PM
SG91camaro
Sep 5, 2015 10:27 PM
