How To Lower a Thirdgen - Video Step by Step
Old Nov 23, 2013 | 12:53 PM
manolis1969's Avatar
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
Hi guys below are two videos where i go step by step on how to lower a thirdgen..
Some of the topics i cover are:
- How to index springs
- how to install lowering springs
- how to cut springs
- how to lower a v6 using v8 lowering eibach springs
- how to replace / install / change rear shocks and springs
....and more
Also please subscribe to my youtube channel (klowny1969] to be notified whenever i post a new video..
Old Dec 18, 2013 | 02:40 PM
Re: How To Lower a Thirdgen - Video Step by Step
Anybody else have a 6 cyl thirdgen that lowered it?
Old Dec 18, 2013 | 08:19 PM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
Good topic. Can you also cover why most cars shake in the rear after lowering.
Old Dec 20, 2013 | 12:28 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Interesting…I lowered mine and it doesn't shake one bit. But I did ensure my pinion angle was correct and added an adjustable pan hard bar with poly bushings…I'm adding LCARBS too.
I do have one issue the cropped up when I lowered mine…I'm using a UMI TQ arm, and the rear e-brake cable rode up against the top of the arm. I need to either add another guide and lengthen the cable slightly, or go with a shielded cable.
Might not be an issue at all if you use the stock TQ arm….
Old Dec 20, 2013 | 05:56 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Great vid!!! Thanks! Only one thing, I have a torque wrench and usually torque everything to spec.. Does it matter if you didn't do it here?
Old Dec 22, 2013 | 01:13 AM
Yeah torque wrench is fine..dont mind me , experience has taught me how much to tighten things down over the years..
Rear hops sometimes when putting rear coil overs in ..
NBrehm
Aug 25, 2015 11:49 PM
3rdgenparts
Aug 6, 2015 09:03 AM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
NBrehm
Aug 5, 2015 07:57 PM
