List your suspension setup!
Old Mar 10, 2014 | 10:04 AM
  #51
gamewiz83's Avatar
Re: List your suspension setup!
Well I made it back okay. Car is now property of Canada
Here it is!
Attached Thumbnails List your suspension setup!-2014-03-09-14.20.01.jpg   List your suspension setup!-2014-03-09-14.20.15.jpg   List your suspension setup!-2014-03-09-14.21.21.jpg
Old Mar 10, 2014 | 11:31 AM
  #52
Alice89's Avatar
Looks good!
Old Mar 10, 2014 | 12:29 PM
  #53
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Very nice!
Old Mar 11, 2014 | 08:18 AM
  #54
echo-delta's Avatar
Old Mar 27, 2014 | 08:58 PM
  #55
B4CHawk's Avatar
Car: 2004 Mazda RX-8
Engine: 1.3l Renesis
Axle/Gears: \
Here goes nothing:
GC Weight jacks
1100# front 230# rear (going to 300#)
Koni Yellows (considering Ridetechs for the rear)
36mm front sway bar with Rodney Dickman Zero Lash end links
Lee 600 series steering box, 12:1
Stock torque arm with poly bushing
Panhard lowered 2", GC adjustable panhard (adding a rod end soon)
Founder's polyball/roto-joint lower control arms (building some aluminum ones)
Strano adjustable rear swaybar on lowest setting
Del-alum A arm bushings going in this week, with custom adjustable steering stops
Ronal R-15s with rt615ks.
Alignment settings:
-2.5 camber
4.8 caster
0 toe
Corner balanced 50/50 cross weight
3690# with driver
Corner balanced and aligned by Darren at West End Alignment
Old Jun 21, 2014 | 04:27 AM
  #56
Phenom-1's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
Here it is!
That's very beautiful man, take good care of it.
Old Jun 25, 2014 | 02:41 PM
  #57
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Mine.....
Front
Springs - Factory
Shocks - KYB (for now)
Wonderbar - UMI
36mm swaybar with poly ES end links and TDS bushings
Strut Mount - Founders
STB - UMI
Complete MOOG front rebuild
Factory IROC Steering Box
Trans Brace - UMI
Rear
Springs - Factory
Shocks - Koni yellow
SFC - Spohn
24mm swaybar with poly ES end links and TDS bushings
LCA - Founders
PH Rod - Founders on-car adj.
PH Rod (upper) - Founders
Auburn LSD
TA Girdle
Old Jun 30, 2014 | 05:11 PM
  #58
BADCAM70's Avatar
Car: 89 IrocZ
Engine: 5.7
Transmission: TH700
Axle/Gears: 2.77
My setup on a 89 Iroc 5.7
Koni yellows with Eibach pro springs in 4 corners
Lakewood boxed lca polybushed
Lakewod adjustable phb polybushed
Spohn tourqe arm
Edelbrock 3point braced struttower
Umi sfc
Energy suspension poly bushed endlinks on swaybars
Ls1 bigbrakes front, 1LE with slotted EBC 11,7 rotors in the back
18inch wheels
Thats all i think, on the street i have the Konis set to soft, when going auto x i tighten them up gives good combo and its a tight ride good on the street.
Old Jun 30, 2014 | 11:34 PM
  #59
Dreambird's Avatar
Car: 1992 Pontiac Trans Am Convertible
Engine: 6.0l LQ4
Axle/Gears: 3.73 True Trac
1992 Trans Am convertible LQ4 swap
Eibach Sportlines
Bilstein struts and shocks
custom homemade strut brace
UMI: rear control arms, panhard bar, subframe connectors, strut mounts
Unbalanced engineering race torque arm
stock sway bars
Spohn bump steer kit
morrow
Jan 13, 2024 12:29 PM
Jorlain
Oct 8, 2015 01:57 AM
angel2794
Sep 8, 2015 06:22 PM
greenyone
Sep 2, 2015 03:39 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
