v6 lowering springs?
Car: 1986 camaro iroc z
Axle/Gears: stock
i have a 1992 pontiac firebird 3.1 v6. im realy wanting to lower it bout 1.75 to 2 inches to get rid of the fender gap a bit but i can not find springs for my situation at all ive searched every were and i have used the search function here i can not find any links to springs available wil lyou guys help me find some thanks mike.
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: v6 lowering springs?
you should be able to use any of the rear springs and I think suspension technique has them for the front
Engine: LQ4 ls 6.0
Here I went and found a part number they are 1 inch but you could cut a inch off Suspension Techniques Sporttech 60115 Lowering Springs
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
there are very few if any options for the v6 cars. cut what you have (not the best idea) Or probably the best yet most expensive way would be weight jacks from ground control
Car: 92 Camaro rs ( mostly stock for now
Engine: 3.1 v6
Transmission: 700r4 with a b&m megashifter.
Axle/Gears: whatever came stock. wanna posi tho
Intrax springs I have used on a v6 before.
Thornburg
Sep 12, 2015 10:11 AM
