I need clearance. Coil info
Old Apr 4, 2014 | 10:27 AM
cason152's Avatar
Car: 1984 Trans Am
Engine: 355, 76 vette block, 11:1 comp
Transmission: th350, b&m master rebuild/shift kit
Axle/Gears: 3.23 posi
Hey yall, couple quick questions. So i want to replace all my coils, with larger, heavier style. Im running true duals, against everyones advice. i have about 4 inches of ground clearance right now with the pipes. Therein lies the problem- i live on dirt roads. So, i need more clearance. Obviously, i could go the route and order new ones on ebay. which will only be a little stiffer. But i figured, if i can find a similar set, some type of suv or truck springs would work the best i.e. stiffer, better lift, etc. Any help or advice would be appreciated. Thanks.
Old Apr 4, 2014 | 05:32 PM
Re: I need clearance. Coil info
Front - Moog 5662
Rear - Moog CC635
db057
Jan 10, 2020 08:55 PM
RedLeader289
Sep 23, 2015 06:50 AM
timonator
Sep 17, 2015 06:57 PM
Night rider327
Sep 16, 2015 02:20 AM
Jlanz55
Sep 6, 2015 03:05 PM
