Factory Suspension Paint
Old Apr 12, 2014 | 12:08 AM
elvstudios's Avatar
Hello, I have a 1986 iroc. The under body is in great shape, but most of they suspension/drivetrain is pretty rusty. I am trying to get it back to a factory clean look so I was wondering what kind of paint/coating i should use. Maybe black por 15 semi gloss? Anyways, I would really appreciate any advice! Thanks Much in advance.
Old Apr 12, 2014 | 12:26 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Factory Suspension Paint
Por-15 is a common suspension paint for rust prevention.
http://www.summitracing.com/int/search/brand/por-15
Old Apr 12, 2014 | 08:09 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
POR is great for items that are already rusted. Just don't use it on clean, shiny metal. It can peel right off.
Old Apr 12, 2014 | 08:47 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Clean, new metal yes. POR 15 works great on bare metal that has been blasted, sanded, or etched.
Old Apr 12, 2014 | 09:44 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I see people put it on over painted things to.
I just remember it flaking off of my bro-n-laws truck when he put some on a painted surface. People still argue with me and do it anyway.
Old Apr 12, 2014 | 09:50 AM
stealtht/a's Avatar
I won't argue... Don't put por15 over paint, it will eventually peel off.
An alternative to POR 15 is to use a rust converter, then a high solids paint like Eastwood chassis black. Properly applied POR 15 will last longer.
Old Apr 12, 2014 | 12:44 PM
naf's Avatar
naf
Properly prepped and etched, no problem with POR but by the time you've done that the chassis black (or another high solids semi) will look better IMO. And you can clean your gun when you're done...
I may have seen too many 'builds' where the entire under car was brushed with POR.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
