Eibach sportline
Car: 1985 IROC Z28
Engine: 355 aluminum heads, comp 294 magnum
Transmission: 700r4 with B&M Mega Shifter
Axle/Gears: Motive 4.10's
Eibach sportline
This past weekend I installed my Sportline kit on my 85 IROC. I love it! I would recommend the kit to anyone looking to lower their car. The car has a real good stance to it now and seems to handle way better! It's a good kit. The swap only took my 35 minutes to get all 4 in and out. Didn't even have take the calipers off the front of the car
here's a photo after the spring swap.
here's a photo after the spring swap. Joined: Jun 2003
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Eibach sportline
Why is the new fender height? What tires do you have? Does anyone know the technical rating on these, all I have ever seen is that they provide a 1.5" drop.
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
I agree I-rocz/28 I have had the pro kit and sportlines and the sportlines are all around better springs even though the pro kit has the better numbers I just don't see it or feel it.
Car: 1985 IROC Z28
Car: 1991 Z28 Vert
The new height over the tire on the front is maybe inch at most. I can barely fit my hand I between the fender and tire now. And the back is maybe 1.5 above the tire. My tires are 245-45R17 The springs dropped the car A LOT more than I was expecting but I'm extremely happy with it.
Car: 1985 IROC Z28
Not a clue.. Have you checked their website any? Might have that information there. It's worth a try. If I had to guess they might be close to what factory spring rates are but with shorter springs..
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Car: 1991 Z28 Vert
