rear isolator removal mod
Old Apr 24, 2014 | 12:02 PM
kitt23's Avatar
if i do this how much of a drop can i expect from this?
Old Apr 24, 2014 | 12:46 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Re: rear isolator removal mod
However thick the isolator is plus the added noise. How much drop do you want?
Old Apr 24, 2014 | 12:59 PM
kitt23's Avatar
1inch front, 1.5-2 back...i got summit lowering springs, cant have front drop more due to risk of the knight rider nose
Old Apr 24, 2014 | 01:02 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
About a 1/2 inch.
JamesC
Old Apr 24, 2014 | 03:38 PM
kitt23's Avatar
okay great. ive read removing it does drop it and it doesnt drop it, does it def drop it?
Old Apr 24, 2014 | 04:12 PM
87350IROC's Avatar
Car: 87' IROC
Think about how it is installed.
Spring - isolator - body. Remove isolator and the car is going to lower however much the installed thickness of the isolator is.
Old Apr 24, 2014 | 04:59 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
The amount of drop depends on how worn your isolators are. Mine were worn almost completely through, and didn't drop the rear any noticeable amount when I removed them.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
