Panhard Rod Relocation Kits are Ready to Ship
Founders Performance panhard rod relocation kit replaces the upper panhard rod support while relocating the lower panhard bar. This relocation kit gives enough room to run up to a 3” true dual exhaust system over the passenger side axle. Kit comes complete with a new heavy duty upper panhard bar support made from 1.25" x .120" high strength DOM steel tubing, CNC laser cut mounting brackets and all new grade 10.9 hardware. Our relocation kit will work with the factory panhard bar and all aftermarket panhard bars.
Features:
- Upper Panhard Bar Built using 1.25" x .120" DOM Tubing
- CNC Laser Cut Mounting Brackets Guarantees Precision Tolerances
- 100% Bolt in Set-Up
- Available Powder Coated Red or Black
ONLY $89.85
http://www.foundersperformance.com/p...elocation-kit/
Features:
ONLY $89.85
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Re: Panhard Rod Relocation Kits are Ready to Ship
looks like a nice piece
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
what do you do for the other end of the panhard bar??
Car: 91 Z28
Transmission: t-56
Axle/Gears: 3.73 4th gen 10 bolt
Just ordered mine last night
. Now maybe my duals will fit properly.
A note to Founders: Will you be producing the relocation bracket for the driver side of the panhard? I need one badly...especially once I get the relocation bar installed. I think Jegs is the only one who offers that right now.
. Now maybe my duals will fit properly.A note to Founders: Will you be producing the relocation bracket for the driver side of the panhard? I need one badly...especially once I get the relocation bar installed. I think Jegs is the only one who offers that right now.
Car: 91 Z28
Transmission: t-56
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
wow how did i miss this? Until now BMR's $220 one was the only option.. for $89 im in x10!.. great deal..
cant wait to see the subframe connectors!
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
I picked one up..just to replace the nasty looking GM factory part.as I have either plated or replaced all the other GM parts..
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
3rdgenparts
Aug 5, 2015 11:57 PM
