Lookie what Im doing [Steering Shaft Change]
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
Steering Shaft Replacement:
The shaft came as a 21 inch collapsed/27 inch expanded piece with 3/4" DD/1"DD. Here is the Flaming River/Boregeson setup cut down, dimpled, and test fit.:
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Re: Lookie what Im doing [Steering Shaft Change]
Well,.............it's purdie
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Nice. Pull the shaft out, bend the brake lines behind the shaft, reinstall shaft. Gives you much better clearance for the headers you are going to be installing.
I would highly recommend you take it back out, spray it dwn real well with brake parts cleaner to get the oils from your fingers off it and then spray some clear coat on it- It will rust in about a month if you don't. The borgeson joints stainless ends will not, but the pivots inside them and the nuts and bolts will...as well as the shaft.
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
Car: 1989 Camaro RS
Engine: Ellis Juan
Transmission: t-56
