Anyone use SPC coil spring spacers?
I just scored a set of Bell Tech Drop spindles.. But I'm already running 900lb hypercoil 5.5" x 12" springs. Giving me roughly a 25.5" front fender height. With 2" Drop spindles my ride height will be way too low.
So since there is no 13" & 14" racing springs in 5.5" diameter; I'm wanting to use a set of aluminum spacers.
I can get them in sets from .375" tall all the way up to 1" tall.
http://www.summitracing.com/parts/sps-1702/overview/
http://www.summitracing.com/search?S...01989%20camaro
So my question is have any of you run these? Any quality control issues; or usage issues?
Any input is appreciated. Thanks...
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: Anyone use SPC coil spring spacers?
I would be scared of them falling out or something, although I have contemplated using them in the past.
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
I put some in my old P/U when I bought it new in 1989 . they are still installed . truck is still in everyday use . it has never been thrashed , beaten , or abused . BUT , I'm not sure about your use . a lot would depend on your use/driving style . good luck .
My car doesn't get airborne if that's what your asking LOL. (que dixie horn)
Thanks for sharing your experience with them. I was curious if anybody had any problems with theirs. Like maybe centering issues. I already ordered 3 sets, So I will find out if they are good or bad...Thanks! Anyone else use them?
Good to know! I was thinking about using these to raise my suspension of my passenger side because it sits lower than my driver's side, so basically to balance out both sides.
Thornburg
Sep 12, 2015 10:11 AM
