Chain noise while driving
Old Jun 4, 2014 | 03:59 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
My 86 t/a seems to have a chain rattle sound in the rear end while driving. Can only really hear it with the windows down. The suspension is pretty much all new. Any ideas?
Old Jun 4, 2014 | 05:05 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: Chain noise while driving
check your rear brake drums.
if it has drums...the chain rattle sound. Is the sound a brake drum makes the pads are 2 wide and have cut the drum into... But that problem its the exact same sound
Old Jun 4, 2014 | 05:11 PM
Joe Tag's Avatar
Washers on the sway bar end links rattle around like chains when the bushings disintegrate, but you said suspension is new. Just in case it's not ALL new.
Old Jun 4, 2014 | 07:46 PM
apie2546's Avatar
Car: 86 Trans Am
Engine: 305 LB9
Rear discs with new brakes will check the end links tonight and see. Not too big a issue just don't want it to be a worry. Thanks for everyones input and ill see what I can find under it
theshackle
Sep 17, 2020 08:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
xxx3man`
Sep 23, 2015 10:37 PM
gta90
Sep 15, 2015 04:00 PM
B_Dubya
Aug 26, 2015 05:09 PM
