Front spring problems......
Old Jun 6, 2014 | 08:21 PM
FormulasOnly's Avatar
Car: 1989 Formula 350
Axle/Gears: 3:23
I just replaced the front springs in my 89 Formula 350 with OEM ACDelco Part# 45H0154. I'm probably going to lower it in the future but I just wanted to get this thing back to stock for the time being.
Problem being is it now has an approach angle that would rival a Humvee.. The fender lip on the drivers side is 29 1/2" and passenger side is 28 1/2.
Is this going to settle out? As a side note I also replaced the lower control arm bushings with Energy Suspension polys and standard KYB struts.
Old Jun 7, 2014 | 07:54 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Front spring problems......
Are they indexed properly between the two drain holes in the spring pocket?
Old Jun 7, 2014 | 07:55 AM
Axle/Gears: 3:23
That's one thing I'm checking this morning...
Old Jun 7, 2014 | 01:07 PM
Axle/Gears: 3:23
They weren't indexed right, now its textbook, dead center between the holes, sway bar hooked up its a little better but still at 29" I think I'll put 100 miles on it and see before I get the eibach kit
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
deracer
Apr 11, 2016 12:04 AM
TA8487
Aug 11, 2015 09:02 PM
