Cutting front IROC Springs
Old Jun 12, 2014 | 08:45 PM
irocz253's Avatar
Car: 1987 Camaro IROC-Z Z28
Engine: Custom Vortec 350
Axle/Gears: 3.73, Auburn Pro Series diff
I have an 87 IROC Z28 that I did a motor swap in. The car is much lighter in the front end now and it sits higher than stock.
I got a new set of IROC springs from a buddy and I want to cut a small amount out of the front springs to compensate for the height.
I was told that I would have to cut a full coil out of the springs so they will be clocked correctly in the strut mount.
^ Is this true?
I was only going to cut 3/4" to 1" out of the front springs to drop the ride height a small amount in the front end.
Advice is appreciated.
And no I do not want lowering springs, I do not want to risk changing my pinion angle as I plan on racing the car.
THANK YOU!
Old Jun 12, 2014 | 09:53 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Re: Cutting front IROC Springs
It's my understanding that the bottom of the spring is the end that has to be indexed. A search could tell you for sure. There are lots of threads on this topic. Lots of guys on here have cut springs. Rule of thumb is a 1/4 coil at a time unless you know exactly how much to cut.
Remember, DO NOT GET THE SPRINGS HOT WHEN YOU CUT THEM!!!!
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
TA8487
Aug 11, 2015 09:02 PM
mustangman65_79
Aug 11, 2015 03:17 PM
