sway bar/coil spring question
Old Jun 28, 2014 | 04:47 PM
excessiveego's Avatar
Car: 1988 Base Coupe
Axle/Gears: 9 bolt w/ disk brakes - 3.70
Im stripping an 84 camaro that has been sitting since 93. The guy that built it died and his wife decided to scrap it and I made a deal with the scrapper to get the parts I want from it. The story is that it was built to be a drag car back in the mid 80's. Dash shows 1,700 miles. It has a built 327/th350 combo and aftermarket suspension. Only issue is, im unsure of what the suspension is.
Everything is red. I found a tag on the springs that reads "806102 made in canada" and the sway bars are like nothing ive seen before. They have square ends with no bolt holes and use a clamp and turnbuckle style adjustable sway bar link with a bracket that mounts to the lower control arm with a built in bump stop.
Anyone have an idea who makes these parts?
Old Jun 28, 2014 | 06:49 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: sway bar/coil spring question
That sounds like Rancho sway bars. Do you have pictures? (Use the advanced editor to upload)
Old Jun 28, 2014 | 09:58 PM
Good possibility. It has rancho shocks in it. Thanks! I didnt even think about them, It looks like they dont offer sway bars for camaros anymore. Do you know if they are any good?
Attached Thumbnails sway bar/coil spring question-10455584_10152912130810828_1419989699910520643_n.jpg
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
ProtoMaster22
Aug 26, 2015 07:50 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
