LS1 Brakes on 1989 T/A
Car: 1989 Pontiac Trans Am
Engine: 5.0 TBI
Hello,
i purchased a complete front LS1 brake kit from scott degeer (bigbrakeupgrade) for my 1989 T/A 5.0 TBI. very good parts!
now my question is:
i use the 16" GTA rims. so scott told me i need to use 4mm spacers.
but i think i read somewhere that it works without spacers too.
can someone help me out where to get 2 or 4 spacers (new or used)? didn't the iroqs use such spacers?
thank you!
best regards andreas
now my question is:
thank you!
Car: '88 Iroc
Engine: Single turbo Vortec 5.7, Megasquirt
Transmission: Probuilt 700r4 3000 stall Vigilante
Axle/Gears: Moser 9" 3.25 w/True Trac
Re: LS1 Brakes on 1989 T/A
I believe some Iroc's (possibly ones that came with aluminum drums?) used spacers in the rear. I would just pick some up off of ebay.
You're gonna love the brakes. I put some LS1 fronts on mine last year. BIG difference!
Car: '87 IROC-Z
Engine: TPI 5.7
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The spacer was apparently used on 16" wheels when GM switched from aluminum to iron drums, which created a .187 size difference. The spacer, however, seems to be hit or miss and essentially unnecessary. Even some disc brake cars received them.
JamesC
Engine: 5.0 TBI
thanks,
now i found some 5mm spacers in our region.
i will try them and look forward how big the difference between the original and the LS1 Brakes will be...
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
IIRC, usually people with ls brakes conversion on the front use the rear wheels on the front with spacers, ideally with a 8.5 mm spacer. The front wheels fit and look great on the back too.
Roblyons
Interior Parts Wanted
Aug 30, 2015 12:07 PM
