car pulls to the left when braking
Old Jul 10, 2014 | 02:08 PM
claus290373's Avatar
Car: Trans Am gta 5.7 1989
Engine: 350 tpi
Transmission: th700r4
Axle/Gears: BG 9 bolt
Hello
when i brake my car pulls to the left but have new brakes and need some idea
what can be wrong.....it fells like the suspension moves when i brake...
have check the a-arms but they are fine...what to do ????
thanks claus
Old Jul 10, 2014 | 02:22 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: car pulls to the left when braking
Does it pull to the left when braking or when letting off the brakes?
If it pulls when hitting the brakes you may have air in the lines, Try re-bleeding. I picked up speed bleeders and did my first brake job with ease.
If it pulls when letting off the brakes, inspect/replace the brake hoses (not lines).
Old Jul 10, 2014 | 02:38 PM
Engine: 350 tpi
its when i am braking.....dont think its air....have check the Idler Arms and one seems to move a lot in the joint where its bolts to the chassis...can this cause the to drag to the side????
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Originally Posted by claus290373
Hello
thanks claus
Rubber brake hoses are bad.
Old Jul 10, 2014 | 02:43 PM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
I'd check the driver's side caliper and then bleed it all out really well.
Old Jul 10, 2014 | 02:54 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
I replaced my hoses with SSB from Russell. My car STILL pulled a little, because of air in the lines. So I got the speed bleeders and all is well. Just saying it's easier to re-bleed than to replace hoses. Please try again.
P.S. Always bleed furthest from the master cylinder first.
Old Jul 11, 2014 | 10:25 AM
Engine: 350 tpi
The braks are ok but the right brake hose is blocked thats why
the car pulls so bad. The right
brake was 50% off
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
