koni shock install questions
Old Jul 19, 2014 | 08:40 PM
chrisfrerick's Avatar
I'm installing koni sport front shocks and I have a few question and problems I came acrossed. here they are
the shocks came with no mounting hardware what hardware do I need?
I noticed my old shock had a large nylon washer but that about it no rubber mounts or anything else.
what size nut is from the top of the nut?
I went to napa and got once that seems to fit but when it got down to the nylon part of the nut i couldn't turn it no more and the nut still covered the holding nut on top of the koni show I couldn't go any further with it. I can't hold the shaft of the strut as it has that plastic guard that cover it.
I'm also worried that I don't have the correct mounting hardware because basically I'll I have was the nut I got at the store that didn't work? I thought about using a non nylon nut but it would still cover the other nut? any help would be great.
Old Jul 20, 2014 | 04:54 PM
Re: koni shock install questions
ok so the bolt is an m15 with 1.5 pitch I got that using my threader kit
Old Jul 20, 2014 | 08:26 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Did you try contacting Koni to see if they'll send you the mounting hardware?
Vintageracer
Jan 10, 2020 05:33 PM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
redmaroz
Aug 16, 2015 11:40 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
