Bought some used 16" wheel A arms
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Like the title says, I went on Ebay and picked up both left and right A arms from a 16" wheel equiped F body. They look decent and bought them from appears to be a decent seller. When they get here, going to have the bushings and other items removed, blast the arms, primer them, and throw some rust preventing black paint. And of course, check the overall condition of the items.
Hopefully, no more rubbing with my R15 wheels since these have the different stops on them compared to my 14" wheel A arms. If this solves the inner fender rubbing, then I was mis informed that spacers would have solved the problem which they havn't.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Bought some used 16" wheel A arms
Since the only difference in the arm is the length of the steering stop, why not just weld extensions on the steering stops you already have to stop the wheel from rubbing? Seems a simpler solution that swapping the entire a arm.
Car: 1987 Camaro LT
Well there isn't anyone that I can trust with the welding in the exact spot. I am going to be throwing on new spindles for the 1LE brakes and pretty much doing a new front end steering kit.
Car: 1987 Camaro LT
Have not posted since I got the A arms. They both arrived dirty which was what I expected. But one did come with the sway bar mounting hole not perfectly round but more of a slight oval. Would this affect handling in any way?
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
For those who may be unaware of a-arm differences:
https://www.thirdgen.org/forums/susp...s-created.html
The egging of the link hole is common as I mention in the link.
JamesC
JamesC
Car: 1987 Camaro LT
Thanks for the info James.
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
Nov 16, 2015 01:13 PM
86IROC112
Sep 7, 2015 01:37 PM
