ball joint install help.
Old Aug 11, 2014 | 04:21 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
I have been trying to install my ball joints for 3 hours. I got them out pretty easy but every time I try to install the new one it goes in crooked. I am using the ball joint press from autozone. Does anyone have any tips on how to not make it go In crooked? I am getting very frustrated. This is on a 91 rs.
Old Aug 11, 2014 | 05:54 PM
camaroyoungster's Avatar
Car: 1985 Camaro Sport Coupe
Engine: Chevy 3.1
Re: ball joint install help.
Just did them in my car. You want the ring that goes around the ball joint that is holding the press against the frame, straight up and down or even a little out away from the a-arm perpendicular to the body. If the "C" part of the press is leaning towards the front of the car on the A-arm it will go in crooked. You can let the "C" part swing around and rest on the front of the A-arm but make sure it is straight up and down or off to the side just a little bit. Good luck to you sir as it is a PITA and it took me several hours to get them in.
Drew
Old Aug 12, 2014 | 10:23 AM
Marc 85Z28's Avatar
If it starts to go crooked hit the clamp HARD with a heavy mallet.
Old Aug 12, 2014 | 01:07 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Store the BJs in the freezer until ready to install and use a bit of oil to help it slide in.
Old Aug 12, 2014 | 01:43 PM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
I used a jack stand after I got them barely started with a c-clamp. Gently lower the car so the ball joint rests directly on the jack stand, then hammer on the a-arm, around the ball joint. I kept re-positioning my jack stand around to whatever side of the ball joint needed to be pressed in more.
You're basically using the weight of the car and hammering, to drive the ball joint in. Make sure to leave the jack under the car for support, just in case the jack stand wants slip.
I found a write-up about this and it worked great. I'll send you the link if I can find it.
red90IROCls1
Aug 25, 2015 06:56 AM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
IROCZ1989
Aug 19, 2015 08:15 AM
MENINBLK
Aug 5, 2015 11:58 PM
NBrehm
Aug 5, 2015 07:57 PM
