Subframe Connectors
Old Feb 4, 2015 | 06:48 PM
dandz28's Avatar
Subframe Connectors
What Subframe connectors do you guys recommend for my car. I have a 1987 Chevy Camaro Z28 the car is being built for the dragstrip. I'm planning on running low 10s what are your thoughts. I thought about the Competition Engineering C3111 bolt in Subframe connectors and I wouled weld them in. What are your thoughts? And I am also gonna install a roll cage either an 8 point or a 10 point. Let me know your thoughts. Thank you
Old Feb 4, 2015 | 07:45 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Re: Subframe Connectors
I got the UMI SFC's.
Old Feb 4, 2015 | 09:51 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I also went with UMI but if you are going to weld in a cage why not make your own connectors? Fueled soul did a good write up on exactly how he did it with pictures. I will make my own inner set same way he did.
Old Feb 4, 2015 | 09:59 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I don't have them yet but like the UMIs box style .
Link = http://www.summitracing.com/search/b...rder=Ascending
Old Feb 4, 2015 | 11:23 PM
Night rider327's Avatar
Car: 1988 Camaro
Spohn sfc here. Great fit and finish.
S&W 10 point cage as well
Old Feb 5, 2015 | 12:36 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Alston Racing SFC's. I liked them so much that I started selling them when I began TDS. They tie the front and rear subframes from the shortest point possible, (hence the least weight). Also I like that the formed sheet metal cups on each end are press-fit onto your subframes on 3-sides when you install them providing a mechanical lock even before you weld them in. Yes I recommend to have them welded in, but these do come with bolts and nuts allowing them to be self-installed, then you can drive the car to a shop that has a welder when the budget allows.
Lon
http://www.top-downsolutions.com/cha...d-(aka-f-body)
Old Feb 9, 2015 | 05:02 PM
Engine: TBI,5.0
Lon
NICE
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
