Bought cut pro-kits, I think I got played.
Old Jun 2, 2015 | 09:13 PM
ChrisV's Avatar
Car: 1990 Iroc
Engine: 305 tpi
I bought eibach pro kits on Craigslist, and was told the front springs were cut for an extra .75" drop. Meaning it would be 1.75 in the front and 1.0 in the rear.
Well I recently installed my front springs, and the car is SLAMMED up front, I mean it is not drive able this way.
I am sitting at 24.5" from ground to fender lip on one side, and 25" on the other.
So I have two questions.
1: is there any way I could've screwed up the install, causing the front end to sit too low?
2: what would be the best way to bring the front end up another inch or so? Is there any adjustable coil spacers I could buy, so that I could level the front end out aswell as raise it another inch or so?
Old Jun 3, 2015 | 05:59 AM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Re: Bought cut pro-kits, I think I got played.
Grab an extra set of the rear spring isolators and install them on the front.... they are 2" thick, but I bet you are sitting on the bump stops.
another option would be to trim your stock springs a little at a time until you get the stance you want
Old Jun 3, 2015 | 10:31 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
I daily drive my car 24.5" from ground to fender lip. It is drivable, you just have to be more cautious.
Old Jun 7, 2015 | 06:21 PM
ChrisV's Avatar
Car: 1990 Iroc
Engine: 305 tpi
Thank you for the replies, found out the car was un even because the isolator had slipped out on the one side, but I went to thicker ones anyways. Car now sits at 25 3/8th of an inch, definitely more street friendly this way!
Jeremys87
Jul 14, 2022 09:08 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
86IROC112
Sep 7, 2015 01:37 PM
johanlindgren
Aug 16, 2015 12:16 AM
TheJoeY88
Aug 13, 2015 06:51 PM
