Spring Compression Tool.... Do I really need?
Old Dec 21, 2001 | 12:48 AM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Got some new KYB struts for the front of my '85 z28. Do I REALLY need this compression tool? I know people that have done it without, but the repair manual says to use one and so does the parts store.......
I thought you just lower the A arm carefully with the jack?
Old Dec 21, 2001 | 01:34 AM
JPrevost's Avatar
Car: 91 Red Sled
You don't need one but it doesn't hurt anything.
I didn't use one, just used the jack and some rope to make sure the spring didn't fly out. The rope just holds the spring to the lower a-arm. Some guys have had success with a metal bar or broam handle shoved up through the a-arm and spring.
It isn't a hard job.
Old Dec 21, 2001 | 03:47 AM
BleedingKnuckles's Avatar
Nope don't need it.
I just put my jack under the control arm and jacked it up and had no problems. You don't need to drop the control arm down though. I just left mine on the jack through the whole process. It's pretty simple.
Old Dec 21, 2001 | 07:08 AM
82camaro's Avatar
Car: 82 camaro SC
You don't remove the spring to install the struts on a third-gen. So it's absolutely not needed for a strut install.
FormulasOnly
Jul 23, 2018 08:47 AM
92projectcamaro
Dec 8, 2015 12:25 AM
tcflint
Sep 27, 2015 05:58 PM
Dragonsys
Sep 25, 2015 03:51 PM
