Front Spring Question
Old Dec 15, 2015 | 06:03 PM
Simon Wu's Avatar
Car: 1992 Chevrolet Camaro RS
Transmission: Manual
Hi Guys:
I purchased these 1903 Front Springs from Hotchkis. I showed them to my mechanic and he said they're the wrong ones and that the front springs are supposed to have the same diameter at the top and at the bottom, and if they taper, they're probably the rear springs. However, after sending them back to Hotchkis, they insisted they were the front springs. Does anybody know what's going on? Are these the front and if so, why do they taper? Can I still install them?
Thanks!
Simon
Old Dec 15, 2015 | 06:38 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Front Spring Question
Did a google. Those are 1903R springs in a 1903F box.
Old Dec 15, 2015 | 06:44 PM
Simon Wu's Avatar
Weird. And I have somebody from Hotchkis telling me they checked the part number on the springs themselves to verify. Thanks for the help!
Old Dec 15, 2015 | 06:51 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
No way there fronts for a 82-92 anyway.
http://www.hawksthirdgenparts.com/ca...op-spring-set/
two on the right in the pic are your fronts.
Old Dec 15, 2015 | 06:59 PM
Simon Wu's Avatar
Got it. I guess the Hotchkis sales guy was just clueless. Thanks for the pic, that makes it crystal clear!
Old Dec 18, 2015 | 06:17 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
You really like the Hotchkis brand or something? Hotchkis are not a performance spring. IE, the front springs are only 600lbs. A stock IROC spring is over 700 and even higher if you trim it. Eibachs will lower it the same, cheaper and have higher spring rates. Double check but the only downside i recall to the eibachs are the rear springs are variable/progresive rates. Linear/constant rates are ideal.
Old Dec 22, 2015 | 07:46 AM
Simon Wu's Avatar
Thanks for the tip! I'm only going with these since i also purchased SFC's from them so thought I would go with some brand consistency...hahaha! But will look closer into the spring rates in the future.
dragonmas
Convertibles
Jan 16, 2016 06:56 PM
Buickstaged
Dec 20, 2015 01:49 PM
MDIROC87
Dec 16, 2015 12:29 PM
1Aauto
Sponsored Vendors
Dec 9, 2015 03:08 PM
camaroz1979
Exterior Parts Wanted
Dec 8, 2015 10:44 PM
