Sub-frame connector modle fitment
Old Jan 27, 2016 | 05:50 PM
dmyruski's Avatar
Car: 92 Camaro Z28
Is there a difference between Hard, T-Top, and Convertible when it comes to sub-frame connectors or are they all universal??
Old Jan 27, 2016 | 06:14 PM
mjdavis68's Avatar
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
Re: Sub-frame connector modle fitment
I read somewhere on here that the convertibles are different
Old Jan 27, 2016 | 06:46 PM
Convertibles are different; they have some reinforcement from the factory that interferes. (which is still inadequate BTW) Others are the same.
Old Jan 27, 2016 | 07:44 PM
dmyruski's Avatar
Car: 92 Camaro Z28
Thank you guys, Much appreciated!
Old Jan 28, 2016 | 09:32 AM
UMI Sales's Avatar
Our weld in design works on both:
http://umiperformance.com/catalog/in...roducts_id=127
Craig
Old Jan 28, 2016 | 10:00 AM
Twin_Turbo's Avatar
UMI,
For a clean install you should really consider changing the design to a bolt in section toe the SFC for the pass front. Welding on powdercoated parts makes for a horrible finish. Just a couple of threaded sleeves in the SFC and some slots or holes in the bracket and some button head allens would do the trick. That's the aprt I hated the most about your SFCs, having to grind off a nice finish,
Old Feb 18, 2016 | 10:20 AM
Augies camaroRS's Avatar
Rusted floor boards around rear subframe
My floor rusted out around the rear subframe and i welded it back up good but still not tight in the rear end like it should. Would subframe connectors help or what should I do? The car is in great shape just bad rust on floor boards.
FreeSpirit
Jun 20, 2016 01:11 AM
V8inMK2
Camaros Wanted
Feb 22, 2016 04:20 PM
kenjames23
Jan 31, 2016 02:23 PM
Jackrabbit501
Jan 24, 2016 09:13 PM
wlooooo
Jan 22, 2016 06:04 PM
