Power rack and pinion on a thirdgen.
Old Feb 1, 2016 | 07:08 PM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
Axle/Gears: moser 4:10
Old Feb 2, 2016 | 12:03 AM
RocketyMan's Avatar
Car: '96 Camaro-Vsux -- SOLD, '84 Z/28
Engine: 3.8L, 305 SBC
Transmission: 4L60E, T-5
Axle/Gears: 3.08s, 3.23s
Re: Power rack and pinion on a thirdgen.
That's kind of neat. Does it run off the stock hydraulic pump on the accessory belt? Have any other pictures too?
Old Feb 2, 2016 | 12:58 AM
Twin_Turbo's Avatar
More details please! End take off R&P, what brand is this? I like that it nicely clears that LS swap, I need a ton more clearance on one of mine because of a large stroke crank and deeper sump. I was thinking about extending the pitman arm but this is a whole lot nicer.
Old Feb 2, 2016 | 01:13 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
I assume that it is not the one that is sold at Hawk's, correct?
Old Feb 2, 2016 | 06:04 AM
Dreambird's Avatar
Car: 1992 Pontiac Trans Am Convertible
Engine: 6.0l LQ4
Axle/Gears: 3.73 True Trac
Ditto more info please
Old Feb 2, 2016 | 12:48 PM
Amillionoh7's Avatar
Car: 92 RS
Engine: Sbc With h/c/i/e holly4150
Transmission: 700r
I have a couple of 2011+ F150 electric racks I want to fab one up for my car.
Old Feb 2, 2016 | 12:56 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Interesting
Old Feb 2, 2016 | 09:02 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Interesting. I remember a ton of the other retrofits gave up steering angle to make it work I think. Which made the turning radius horrible, and its already 39ft stock.
Old Feb 2, 2016 | 09:19 PM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
It's a racing rack from Flaming River, but everything else is hand made. It requires short spindle arms to get full turn.
Old Feb 2, 2016 | 09:26 PM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
Spindle.
Old Feb 2, 2016 | 11:42 PM
RocketyMan's Avatar
Oh Cool! How much does the whole unit weigh? Possible weight savings??
Old Feb 3, 2016 | 12:03 AM
Dreambird's Avatar
Engine: 6.0l LQ4
What P/N rack did you get? where did you get the bracket that attaches to the rack and the tie rods (Black part)? Was it a kit? I didn't see a setup like yours in the racing racks section? How much of the steering arms did you remove to get the full turn radius? Sorry for so many questions but that is really cool! would love to see some more build picts.
Old Feb 3, 2016 | 12:16 AM
Twin_Turbo's Avatar
OK, why does it need shorter steering knuckles? With an end take off you are pretty loose in where you place the tie rod ends on the center mount, you can easily taylor spacing and height. I do not see why on earth you would need shorter arms unless it has very short travel. From the looks of the harmonica boots it probably has. With an ETO you can have a much wider rack than that as rack width is not a real issue, it's just a packaging issue not a geometry issue.
It does look like a quality install, just not too fond of mig welded ends on cast spindles. Ddi you get it all x rayed?
Old Feb 3, 2016 | 05:57 AM
TTOP350's Avatar
With the way all the racks are designed, (short travel) they need that shorter spindle knuckle to keep the stockish turning radius.
I have friends that weld to cast all the time. Its ok as long as you know how and what to use.
Old Feb 3, 2016 | 06:29 AM
LX_SS's Avatar
Car: 85 Firebird C&C T-Top
Engine: 347ci LS1
Transmission: 4L60E LS1
Axle/Gears: BW 9 Bolt Posi,3.27,C5+VE Brakes
When i measure up the rack travel of stock spindles it came to 7 inches, the only cto rack i could find with the travel required was : http://retrorack.com.au/indiv-retror...d-lhd-ausfscto
Obviously the rhd version for me, but it was just too pricey for me to get.
Old Feb 3, 2016 | 08:00 AM
Yeah, holy crap.
Would be interesting if someone made a drop spindle with shorter arms. Would make rack conversions much more popular.
Old Feb 5, 2016 | 09:24 AM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
With regards to twin turbo. There was no need to x-ray the spindles because no welding was done to the iron.
Old Feb 5, 2016 | 09:36 AM
Twin_Turbo's Avatar
Oh I see it now, it's sort of a sleeve that's bolted on. Nifty
Old Feb 5, 2016 | 10:06 AM
Pocket's Avatar
Car: 91 Trans Am
Looks nice. Id get longer bolts where the tierod connects to the spindle. Rule of thumb is 1/2 the diameter of the bolt must extend past the nut. Looks like it stops just as it touches the nylon, so its locking aspect is lost completely as well. Drilling through for a cotter pin or other mechanical lock wouldnt be a bad idea either
Old Feb 5, 2016 | 12:04 PM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
The bolts in the pic were not used. For those interested in more details there are so many mods that have to be done to make this work. Obviously the spindles must be shorter to get full turn and to keep the ratio fast. The others are my motor is moved back 2 inch's. I doubt a motor in stock position would work. I also have a under drive balancer to get the rack high enough. Everything about this conversion you don't have enough space. I'm sure that's why no one makes a kit for them.
Old Feb 5, 2016 | 04:25 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
How about who use the low mounted AC comp.The tie rod nut just rubs unless the idler arm is lowered a bit.I know there's no idler arm/tie rod or compressor, but anything of a sort like that with this set up?
Old Feb 10, 2016 | 04:23 PM
83RDRACR's Avatar
TVC, thanks for the email to check this out. That was the rack that gave me the idea to fixing my problem of the rack interfering with the damper on my build. Both of our cars have extensive mods, yours has the engine setback and custom steering arms and mine has the wheelbase moved 5" forward and 4th gen spindles. All that and we still have clearance issues with the rack. I see on flaming river that your rack is very similar to the onr they use in there 2nd gen camaro kits. Also they list a XL rack that has 6" of travel and a custom make to order road race rack. All 3 of these would be possibilities for a 3rd gen swap but still a lot of fabrication and expense.
As always great work and craftsman ship from you.
Dave
Old Apr 1, 2016 | 08:18 AM
prossi's Avatar
no more sway bar??
Old Apr 13, 2016 | 06:29 PM
tvc 15's Avatar
Car: 88 rs
Engine: ls1
Transmission: t56
The sway bar was not on in that pic. But the sway bar is one of the things that makes the rack such a tight fit. At full lock the end of the rack just misses the sway bar.
project89
Jun 13, 2008 09:48 PM
Stekman
Mar 15, 2005 11:09 AM
breathment
Aug 9, 2002 11:51 PM
breathment
Mar 26, 2002 12:20 AM
un4givin89
Mar 15, 2002 11:43 AM
