choosing correct springs with ls1 swap
Old Feb 26, 2016 | 10:15 PM
timonator's Avatar
Im going to redo the suspension on my gta with ls1 swap. When I did the swap last year the stock height spring gave it 60s gasser stance. I cut a coil off each front spring. It now has about stock ride height. I want to put dome good springs on it that will also put it closer to the ground. None of the front springs that I have seen are specially for an LS swapped car.
Old Feb 26, 2016 | 11:19 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Re: choosing correct springs with ls1 swap
If all you want is to change your ride height, cut the springs more. It increases the spring rates as they get shorter anyway.
I've also never seen LS swap specific springs. I have GC weight jacks and they are set lower than before my LS1 swap to achieve the same ride height I had with the old cast iron SBC.
What do you use the car for? Street, strip, autoX?
Old Feb 27, 2016 | 07:50 AM
timonator's Avatar
Mostly street. May auto x it.
Old Feb 27, 2016 | 08:58 AM
Car: 92 Camaro RS
I started autoXing on old stock suspension since then the suspension mods have spiraled out of control! I'd hate to see you buy springs now, get into autoX and then want to upgrade to weight jacks and buy springs twice.
Since you've already cut your springs, shouldn't be a big deal for you to do it again. I'd do that, and remember not to let the springs get hot when you cut them. Cutting the springs will raise your spring rates which is good for handling and of course, lower it to your desired ride height. Give autoX a try and go from there.
Best mods for autoX in order are:
1.Driver mod
2.Tires
3.Struts and shocks
4.Springs
Absolutely get a wonderbar!
Old Feb 27, 2016 | 09:03 AM
timonator's Avatar
1.Driver mod
2.Tires
3.Struts and shocks
4.Springs
I have a wonderbar, just bought a set of konis. Tires are brand new stock size hankooks.
I have autocrossed my 70 GSX but the GTA handles so much better.
I just thought I might want to change the springs while it's all apart.
Old Mar 3, 2016 | 02:39 PM
Ikes 91Z's Avatar
Car: 1991 Camaro Z28
Engine: LS Conversion
Axle/Gears: Stock for now...
I just replaced my old springs with the eibach sport lines. Stance is good but not specific to LS swap.
My old springs were very rusty, and since the rest of the front end was new I replaced them. Mine is just gonna be a street driver when I am done with the swap though too.
Whitechevy92
Brakes
Oct 25, 2016 09:56 PM
John Hagan
Mar 12, 2016 02:22 PM
skirocz28
Interior Parts Wanted
Feb 14, 2016 09:50 AM
L-Train8
Feb 5, 2016 03:30 PM
SsBenj
LSX and LTX Parts
Jan 31, 2016 11:18 PM
