HELP!!! I just put on rear pads and now my rear brakes dont work!!!!
Old Dec 24, 2001 | 12:30 AM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
I replaced the rear brake pads on my 83 Trans Am and even while the back end is up in the air, I cant stop the wheels from spinning no matter how hard i push the pedal. They slow a little bit, but they dont quite stop. I replaced the master cylinder too cause it was leaking a little bit. I even bled the brakes at all 4 corners twice! I cant figure it out. How do you adjust them up? I ratcheted the e-brake up over 100 times thinking that might do it, but it didnt. BTW, emergency brake is tightened correctly. The pedal does feel a little spongy though. What could be doing this? Please help me as this is my only method of transportation and I dont feel very safe driving with just front brakes. Thanks in advance.
Old Dec 24, 2001 | 06:23 AM
Blackbari's Avatar
Car: 1988 IROC
Engine: B2L
Transmission: MD8
Axle/Gears: 2.77 9 Bolt
Calipers
If you have rear disc brakes, have you checked to see if the rear calipers are working? That is, are the caliper cylinders not frozen due to rust? I found out my '88 IROC's rear calipers were rusted and had to replace them.
Old Dec 24, 2001 | 12:26 PM
84L69TA's Avatar
Car: 4 Mopars total
Well, the emergency brake works, so I'm assuming the calipers arent frozen. The rear brakes worked before I replaced the pads. Anyway, any other ideas??? Thanks.
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
kyleb24
Aug 15, 2015 08:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
