Hotchkis springs vs. Eibach ?
Old Dec 24, 2001 | 08:40 AM
formul8!!'s Avatar
Car: 2004 GTO
Has any one used either? I kee reading that the Eibach prokit is too soft but have not heard any one use the Hotckis springs.
Any info would be appreciated!
Old Dec 27, 2001 | 10:19 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Never had experience with the Hotchkis;I've always went with the Eibach springs. I have the Sportlines and have liked them very much. I haven't actually tested on a skidpad for g's,but around a specific curve on a course I gained almost 15 mph after installing just the springs,and 25 total with the springs and bigger sway bars. Hard braking is better because of the extra force on the front tires. But as far as the differences between the two companies,I can't offer any opinions.I can just tell you that I have been happy with the Eibachs.Here is a picture of my car with the Eibachs installed.Not a good pic,just the only one I could find at the moment.
Old Dec 28, 2001 | 09:30 AM
formul8!!'s Avatar
Car: 2004 GTO
Thanks for the info!
Damn, your car looks sweet with the cowl hood and the ROH Snypers!!
Old Dec 29, 2001 | 02:01 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I like my Hotchkis springs. A bit stiffer then the WS6 springs and about 1" lower.
Old Dec 30, 2001 | 01:23 PM
lodavis's Avatar
I have the Eibach Prokit springs on my 86 IROC and definately
noticed an improvement in handling after putting them on.
They do ride quite a bit harder than the stock springs, but the
lowering isn't substantial. I haven't ridden in a thirdgen with the
Sportlines, but I can say that the prokit definately does not ride soft.
Also, my IROC has 245/45/16 Bridgestone RE730's on it so
this may add to the hard ride.
I also gained about 15mph around turns from stock springs.
Overall, I think that the increased handling would be
justification for buying the eibachs.
By the way RSSpeed, you're car is looking sweet,
I hope to do that with mine in the future.
Old Dec 30, 2001 | 08:16 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
I have the Hotchkis on my Z.I felt the Eibach lowered the car too much and the Hotchkis was just right at 1",with great handling and ride.
Old Dec 31, 2001 | 04:43 AM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
The Eibach Sportlines are higher rate (stiffer) than stock springs but do not have as high a rate as the Eibach Prokit springs.
The Sportlines drop around 1 5/8" - 1 3/4" in front and around 1 1/3" - 1 1/2" in rear for a little bit of a raked look.
The Prokit drops around 1" front and back.
The Sportlines are primarily to get a "slammed look".
The Prokit springs are primarily for improved handling.
The Hotchkis springs are very comparable to the Prokit springs.
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
