Panhard bar relocation, UMI vs BMR vs Founders
Old Jun 14, 2016 | 08:11 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Seems all three look identical. Im leaning towards the UMI piece because I have their RR K member +A Arms which is nice quality. Only thing bothering me is the Founders piece is $100 less than the other two. Anyone using these have an opinion? Im stock ride height with a fab 9 inch rear. Thanks
Old Jun 14, 2016 | 12:14 PM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Re: Panhard bar relocation, UMI vs BMR vs Founders
I recently installed the Founder's piece. I put it in so I can have more access to run a bigger exhaust. Welds look great. Solid unit.
Old Jun 18, 2016 | 11:29 AM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
I picked up founders. just to replace the stock upper bar..good looking part. not in yet.
Old Jun 18, 2016 | 03:46 PM
IROCZ1989's Avatar
Car: 1989 IrocZ
This is what Im wondering. Same part two different prices. Btw nice rear end. Whats the internals?
Old Jun 18, 2016 | 05:29 PM
that one is 31 spline 4.11 Detroit locker Daytona support. cast iron.
but as the trans is now a close ratio with a trans brake I upgraded to
to a bit more..also dropped 20lbs more off the car.
the upgrade is a aluminum set up with a bigger Daytona support and a bit more gear with a Detroit Locker.
the iron unit is getting boxed up and stored...ill pick up a 2nd aluminum housing and replace the iron unit.always have a back up unit.
Old Jun 28, 2016 | 08:05 AM
SOCAL-Z's Avatar
Car: 87' IROC
I have the Founders Performance as well, great part.
Old Jun 28, 2016 | 08:37 AM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Tcrasher
Nov 26, 2016 12:44 PM
2012sergen11
Interior Parts Wanted
Jun 5, 2016 09:43 AM
Dukey726
Jun 1, 2016 06:25 PM
