Auto to manual......
Old Dec 26, 2001 | 02:30 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I'm putting in a T56 to replace my 700r4. My buddies and I can do the tranny swap, but we're all worried about putting in the pedals and hydrolic line. My question is: Can I have the pedal assembly put in along with the master/slave cylinder and resovuor, while keeping my auto in thier? Obviously, the clutch's hydrolic cable won't be hooked up at that time. But will the brake assembly work? I'll need to drive it from the mechanic's to the garage.
Old Dec 26, 2001 | 09:03 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yes. I swapped the pedals in on one weekend and the T5 the following weekend. I am assuming you are using a new GM master/slave cylinder unit. Keep the plastic tethers in place that prevents the slave unit from moving. Don't hook up the push rod to the clutch pedal until you have the rest in place so you don't accidentally push it in. Good luck, Lon.
Linson
Oct 24, 2025 02:00 PM
sp8ty
South East Region
Sep 24, 2018 03:55 PM
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Linson
Oct 1, 2015 09:50 PM
