Front wheels scratch in turn
Car: 1989 Gray ttop GTA
Engine: 5700cc
Transmission: auto 700R4
Hi
I've already asked this inside another topic, but I would like to open this to talk about this behaviour: when turned at maximum, my front wheels always scratches the ground, like they are forced to "hop" the ground. No matter what.
Wheels angle are fine, tires are nice, car linkages are ok.
In this video you can barely see it:
Is this normal?
Does it happen to you?
THANKS!!
Is this normal?
THANKS!!
Car: check
Engine: check
Transmission: check
Re: Front wheels scratch in turn
It is normal, the ackerman angles aren't that good with the stock suspension. And the hopping is made worse with wide tires.
I try to avoid full lock steering, and when I do full lock I move the car slowly.
RBob.
RBob.
Engine: 5700cc
yeah, thanks, ill read about it.
Do you know if it happens to 4th gens also?
Is it dangerous for the whole linkage?
thanks sir!!
thanks sir!!
