Idler arm
Old Dec 13, 2016 | 02:49 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Idler arm
The idler arm on my car has some play in it, would this Ebay offer a good replacement?
http://www.ebay.com/itm/Idler-Arm-fo...FXdmdN&vxp=mtr
Old Dec 13, 2016 | 03:18 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Idler arm
I'd go with a name brand like moog k6249.
I did use a mevotech mk6249 on my 91z28 seems like a nice piece for a lower price point.
I'm always Leary of cheap steering and brake parts. If something fails because it's junk well....
Old Dec 13, 2016 | 03:20 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Idler arm
Just be careful on what you buy.. read this.
https://www.thirdgen.org/forums/susp...dler-arms.html
For what its Worth.....stick to name brand components.
I realize you being over the pond and all, but just be carful what you choose.
Good luck
Old Dec 13, 2016 | 03:52 PM
Re: Idler arm
Good luck
Thanks a lot!
Old Dec 13, 2016 | 04:06 PM
Re: Idler arm
I just bought: NAPA 268-3635 on Ebay.
Old Dec 14, 2016 | 06:32 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Idler arm
It looks like it was salvaged off the ocean floor.
Old Dec 14, 2016 | 07:24 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Idler arm
I thought something along those lines QwkTrip!
Old Dec 14, 2016 | 09:58 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: Idler arm
Looks Like It Has No Grease Fitting.
Old Dec 15, 2016 | 02:38 AM
Re: Idler arm
Older design maybe?
It just needs a fresh coat of black paint I guess...
Btw, I bought the AC Delco 45C1065 arm from Rockauto as well, so I can compare before which one to use..
Old Dec 15, 2016 | 06:54 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Idler arm
More like cheap junk, or somebody sold you their old used part. The 30 year old parts on my car look better than that.
Let me ask you a question... does NAPA sell parts on ebay?
Old Dec 15, 2016 | 07:01 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Idler arm
Probably not, but others certainly sell NAPA boxed parts.
Old Dec 15, 2016 | 09:33 AM
gt4373's Avatar
Re: Idler arm
Originally Posted by Fire"Dutch"Bird
Older design maybe?
The GM Part Is The Way To Go.
Old Dec 15, 2016 | 11:51 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Re: Idler arm
AC Delco and Rock Auto....Don't mess with the other stuff, it is mostly junk.
Old Dec 15, 2016 | 02:14 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Re: Idler arm
I WAS A "Stocking Dealer" for Moog in the 1970-80's and have used their parts since. Moog is top notch!
Old Dec 26, 2016 | 12:20 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: Idler arm
wow....patina is a class all by its self...
that thing looks like it came off a **** sub..a sunken **** sub...
Old Dec 26, 2016 | 12:31 PM
Re: Idler arm
Nappa sub...
Old Dec 26, 2016 | 12:37 PM
Engine: Lb9
Transmission: M20
Re: Idler arm
Napa u-boat lol
Old Dec 26, 2016 | 02:23 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Idler arm
Been a lot of flooding the last few years. Wonder if some crumb is reselling trashed stock from a flooded store.
I still suspect it is an old used part somebody took off their car though.
Old Dec 26, 2016 | 04:09 PM
Re: Idler arm
http://www.ebay.nl/itm/282138834884?...%3AMEBIDX%3AIT
Old Dec 26, 2016 | 07:06 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Idler arm
The idler arm on my car has some play in it....[snip]
It's probably too late, but you need to check "play" in the idler arm as specified in the service manual. Unless you like throwing perfectly good parts in the trash.
I've had more than a few alignment shops tell me mine was worn out when it was still good.
Old Dec 27, 2016 | 12:40 AM
Re: Idler arm
Thanks, I will check it out, next time I'm under the car!
Old Jan 4, 2017 | 07:26 AM
Re: Idler arm
Recieved the AC Delco 45C1065 arm from Rockauto today.
On the Rockauto order it says: "Made in China", on the AC Delco box it says: "Made in USA"....???
There is no "Made in the USA" stamped on the AC Delco arm though, just some numbers...6717-C WAN8.
The Delco arm angle is excact the same as the angle on the "old" new Nappa arm I bought as well, see above.
Old Jan 4, 2017 | 07:39 AM
Re: Idler arm
Just sprayed a little WD-40 on it, and it looks like new (again..)..!!
