Sway bar bolts
Car: 1986 Iroc Z28
Sway bar bolts
I just had the frame behind my steering box repaired, and in the process the welder accidentally snapped the bolts that hold the sway bar down. Would these be the right replacements?? http://www.spohn.net/shop/1982-1992-GM-F-Body/Suspension/Polyurethane-Bushings-Accessories/Polyurethane-End-Link-Set-Front-Sway-Bar.html
Re: Sway bar bolts
That's them.
Axle/Gears: 3.45, 3.27, 3.27
Re: Sway bar bolts
What you have linked is the end links. From your description it sounded as if you were referring to the front sway bar mount bolts. If so I have them available:
http://www.top-downsolutions.com/cha...ic-flange-bolt
Lon Salgren
Lon Salgren
