Wield steering issue left over from P.O.
Old Apr 21, 2017 | 08:56 PM
broke91firebird's Avatar
Car: 1991 Pontiac Firebird convertible
Engine: 3.1 soon to be 3.4/3100
Axle/Gears: original gears, for now
I have a weird steering issue. Is there anyway to center the steering box on an 86 camaro? Below are the pictures of the car currently. It's got a good week old alignment and all 4 sets of tierods are fairly even. The tire picture is taken with both steering arms straight.
3 turns left to stop, 1.5 turns to the right.
pictures won the load off my phone, they'll be below
Old Apr 21, 2017 | 08:58 PM
Re: Wield steering issue left over from P.O.
both arms are straight
both wheels turned about 15 degrees
With the steering arms straight, both wheels are turned about 15 degrees to the left
Old Apr 21, 2017 | 09:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
It looks to me like the alignment tech messed up bad.
when the steering wheel is straight, and the pitman arm straight are the wheels cocked?
are both inner and outer tie tods on both sides of each assembly the same length? Maybe the wrong parts were installed?
is the steering wheel aftermarket? The factory ones and most quality ones are indexed/keyed and can only be installed one way, same with the pitman arm
. So something else is wrong here
Old Apr 21, 2017 | 10:25 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Based on your numbers, it just so happens the steering wheel is off center by about 1 full revolution. What a coinkydink.
Old Apr 23, 2017 | 04:54 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I would start looking at the steering gear and work my way through the linkage to the wheels.
Typically, the steering gear is on-center when the flat of the stub shaft is on the same side and parallel with the side cover.
