Power steering brackets for metric pumps
Old 04-24-2017, 09:56 AM
SilverChicken's Avatar
Car: 1986 Pontiac Firebird
Engine: 383 SBC
Axle/Gears: Hawks 8.8 with 4.10’s
So I goofed a while back and bought the march ps pump kit for '79- older Saginaw pumps thanks to the seller's asinine compatibility description. Stupidly expensive for what it is I'd like to find a setup that fits these metric pumps but isn't $110+. Steel parts are fine as long as it ditches the exhaust stud mounting so the horrendous, over-complicated factory junk is off the table. Anyone know of a manufacturer, part number, anything?
Old 04-24-2017, 03:15 PM
Biledriver's Avatar
Car: 87 firebird 86 c10 90 mustang
Engine: 383 sbc
Transmission: 97 t56
Axle/Gears: Moser 12 bolt 3.73
Re: Power steering brackets for metric pumps
I don't have a catalog in front of me but look at allstar performance. They have cool simple circle track stuff that's more reasonable than most big catalogs.
Old 04-26-2017, 05:53 AM
Engine: 383 SBC
Good idea. I've got a speedway race catalogue around here somewhere I'll look through.
Old 05-05-2017, 05:48 AM
83 Crossfire TA's Avatar
what style mount?
I've used this style:
http://www.ebay.com/itm/SBC-Black-Lw...item20faa51c0a
which is listed for the 79 and older stuff but I don't remember having to modify anything to make it work with a metric ('87 f-body) pump. I did make the slot longer on it (cut that part of the bracket and re-welded it) but that was because I needed the pump in a different position to clear stuff on the front of my cylinder head.
I still have my bracket assembly, I ditched it because I finally figured out that all the saginaw pumps that I could get my hands on were junk and swapped to a type II.
Old 05-05-2017, 03:23 PM
Engine: 383 SBC
Going over to a type II is ultimately what I'd like to do, only it seems a little pricey up front. What I've seen is v-belt pumps with remote reservior are around $250 and up.
As far far as the mount setup you showed there's one stud in the back of the pump that's in a different spot than the earlier style pumps and that's what makes them compatible or not.
