1983 firebird needs new bushing in the front control arms. I have them out because I was replacing engine mounts and ball joints. I want to replace the bushings too. has anyone done this at home? My garage is well equipped, but no hydrolic press
JamesC
close
It can be done.
There are various presses that can be made with a threaded rod, bolts, and washers, but the easiest way tends to be to take a propane torch, heat the rubber till it separates from the shell (smelly/smoky mess) and then just use a hacksaw or Sawzall to cut a slit in the shell and then you can just push it out.
Putting them back in can sometimes be done with a hammer and socket after you get everything clean. I'd suggest making a spacer (half of a piece of exhaust tubing) to keep from crushing the 'ears" trying to force the new bushing back in.
i threw my del a lum bushings in the freezer for a few days then pressed them in with a big vise.
got t done with threaded rod and chunks of pipe
Quote:
I did this a few weeks ago on a 1992 Camaro RS.Originally Posted by norton750
1983 firebird needs new bushing in the front control arms. I have them out because I was replacing engine mounts and ball joints. I want to replace the bushings too. has anyone done this at home? My garage is well equipped, but no hydrolic press You will need 2 custom spacers to keep the feet of the A-arm from bending inward.(I cut a pipe in 1/2 and ground the ends untill they fit snug)
i used all-thead and a bunch of washers and nuts to press the old bushings out.
I used a small saw to cut a grove in the sleeve and hammered it out.
With the new poly bushings, it's easier to press in the new sleeves first then then Greased poly.
I used the same all-thread/washer combo to press them in.
DO NOT use a ball joint press for this
It's hard to explain the washer /all thread thing, but it's very similar to what this YouTube video does.
https://m.youtube.com/watch?v=50VUhlxlO-M
got one side done and back in. similar to what you describe. working on the second side now. thanks
