Ball joint castle nut failure, help!
Old Jun 22, 2017 | 12:10 AM
WhiskeyChick's Avatar
Car: 1987 Trans Am GTA
Engine: 305 V8
Transmission: 5spd
Axle/Gears: 9bolt
So last night as im parking my gta i hear this loud bang from my pass front end. Get out and car is sitting on the tire, with the control arm on the inside of my rim.
the castle nut sheared off the cotter pin, (there was a piece left in the center hole) and tore the bottom half of the threads out of the castle nut. The ball joint stud itself was undamaged (was replaced a couple years ago) as was everything else minus a scratch in my rim thankfully.
I put the ball joint back into the spindle (I have lowering spindles) and a new castle nut and new cotter pin and drove it home.
problem. I'm now super nervous to drive it because I have no idea why it did this! Anyone heard or had anything like this happen before? I searched but only found a couple threads where cotter pins were forgotten. Thanks
Old Jun 22, 2017 | 01:58 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: Ball joint castle nut failure, help!
seems like a lot of parts today from foreign countries come with sub-standard hardware. your better off to re-use the factory castle nut.
i was changing upper ball joints on a truck i have and read reviews of people having easily stripped hardware. i went and bought all new grade 8 hardware, then stuck the replacement bolts in a vise to see if they would have stripped or not? i'll bet i didnt put 15 ft lbs on them before they stripped !!! threw the castle nuts away and re-used the old factory ones.
Old Jun 22, 2017 | 12:07 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Sounds more like to me the castle nuts wasn't torqued properly when the joint was installed ad the tapered connection was never seated completely. The assemby was loose and the castle nut was the only thing holding the joint together, and eventually it finally failed. replace it, tighten it and you should be good
Old Jun 22, 2017 | 03:14 PM
83 Crossfire TA's Avatar
Yea, I re-read the original post 3x trying to figure out what exactly happened.
I don't see how the ball joint nut would have backed off if it was properly installed even if the cotter pin was forgotten, and I don't see how you could have driven around with it loose and the taper not seated without knowing something was wrong/moving around, and for that matter, I'm not sure how the nut could have backed off to that point without messing up the threads.
Even if it was a cheap aluminum cotter pin as opposed to proper steel one (not sure why they even make the aluminum ones), it would take quite a bit of force to shear both sides of the cotter pin back the nut out with it installed, I can't imaging it happening if it was installed correctly to start with.
Old Jun 22, 2017 | 08:58 PM
Hiemarch's Avatar
Car: 1991 firebird formula convertible
Engine: 377 Small block
Transmission: 700R4 Done up
I had that happen to me quite a few years back when I first built up a car, exact same thing castle nut sheared off the cotter pin and catastrophic faliure crossing over rail road tracks at 20MPH. thankfully it did not happen the day before!!!! I was doing high speed runs tuning the upper RPM of the car at around 160MPH+. The entire front end was brand new and installed by me (20 year licensed mechanic). They where cheap Ebay parts and supplied to me and that was the last time I installed anything that cheap!
Long story short, I never figured out why it backed off but I do know the folowing day the entire front end got replaced with MOOG parts!
Old Jun 22, 2017 | 09:13 PM
NoEmissions84TA's Avatar
Got any enemies?? Sabotage??
Old Jun 23, 2017 | 12:08 PM
Engine: 305 V8
Transmission: 5spd
Axle/Gears: 9bolt
Yea I bought the high quality stuff, is why i'm worried. I haven't ripped into the front end yet just parked it until the weekend.
No enemies lol, and I doubt sabotage
Old Jul 19, 2017 | 09:38 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
When I re-did my front end with a new k member and a arms I found one of the castle nuts holding on by like 1 thread and the cotter pin sheered off just like you describe...the ball joint stud was still pressed into the spindle and I still had to use the ball joint tool to get it out....didn't think too much about it till now...guess I'm lucky
Old Jul 19, 2017 | 10:13 PM
Engine: 305 V8
Transmission: 5spd
Axle/Gears: 9bolt
Yea, since I posted I checked everything over nothing looked wrong. Put the ball joint back into the spindle and a new Castle nut and pin on it, been a few hundred kilometers since then and haven't had any issuse since. Checked on it a couple times and still nice and tight.
Old May 15, 2024 | 02:47 PM
JedediahSmith's Avatar
Did you ever figure out what happened. I just had the same exact same thing happen to me 10 minutes ago. No warning signs, wheel just folded under the van as I was turning around in the driveway. ball joint is still good but the crown nut and cotter pin are gone. The ball joint was replaced about 6 weeks ago and I'm sure I tightened it and put the cotter pin in. I can't understand how this is even possible.
Old May 15, 2024 | 07:43 PM
Engine: 305 V8
Transmission: 5spd
Axle/Gears: 9bolt
Honestly, I think it was a faulty casting of the nut. The threads just ripped out, I've been driving it ever since with the same ball joint and a new nut and cotter pin.
