Size of OEM '86 Rear Swaybar?
Old Jun 23, 2017 | 04:48 AM
Trickskier's Avatar
Car: 2014 ZL1 / 1986 IROC-Z
Can someone tell me the diameter of an OEM Swaybar on a 1986 IROC-Z? Is it 7/8" (22MM) or 1" (25MM)?
Old Jun 23, 2017 | 01:16 PM
83 Crossfire TA's Avatar
Re: Size of OEM '86 Rear Swaybar?
What sway bar, springs... the car came with depends on the options it was shipped with.
Old Jun 23, 2017 | 03:37 PM
Trickskier's Avatar
Sorry - Rear Swaybar. What options do you need to know?
Old Jun 23, 2017 | 09:21 PM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
In 1986 it should be a 23mm rear bar - although it could be a 21mm (Z28). 24mm came on the WS6 and as far as I know, no f-body came with a 25mm from GM.
Easy to measure the bar if you have it.
Old Jun 24, 2017 | 05:28 AM
Trickskier's Avatar
Thank You!
Old Sep 24, 2017 | 11:30 AM
Oddball's Avatar
Car: '86 IROC-Z
Engine: LG4 305-4BBL
Measured my sway bars to order new bushings yesterday. My 86 IROC has 34 in front, 23 in rear.
