Cutting front wheel wells
Old Jul 20, 2017 | 12:26 PM
Willie B.'s Avatar
Car: 91camaro
Engine: 5.3
I just curious as to how far has some cut the front wheel wells back to the struts without having to brace it with tubing?
Old Jul 23, 2017 | 09:47 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Cutting front wheel wells
I wouldn't cut the wheel well arches unless you were putting in a cage. I would also look into fabricating a bar to reconnect your core support. Are you even running a front bumper? Without that core support connecting the front (and a bumper) you're asking the K-member and Wonder Bar (you at least have a wonder bar, right?) to do a lot more than they were designed for. Especially for a car that's pushing probably 600 hp(?) to the wheels.
Old Jul 27, 2017 | 06:58 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
I agree, the entire wheel arch is support for the strut/spring, also the upper rad support is also part of the structure of the cAR and should not have been cut without something in its place, that's asking for the strut towers to colapse in a turn
