Front subframe
Old Aug 1, 2017 | 10:19 AM
ItalianIroc-Z's Avatar
Front subframe
hi guys
i have a 1986 camaro with the front subframe bolts that wont come out i dont really feel like cutting thru the frame to reach the nuts what is another solution to remove the bolts
thanks
Old Aug 1, 2017 | 10:27 AM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Re: Front subframe
Only other option I can think of is to cut or grind off the bolt heads then deal with is after the K member is removed.
But that will be a challenge as well. The nuts are "floating inserts" inside the frame.
Perhaps another route is to drill a small hole to allow you to spray penetrating oil on the nuts and end of the bolts. Have you tried a good impact wrench with a large 3/8 or 1/2" air hose? that might work as well. past that no bright ideas...
Old Aug 1, 2017 | 10:33 AM
Re: Front subframe
ok i didnt think of making a small hole to pass lubricant on the bolt
thank you
Old Aug 2, 2017 | 03:16 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Front subframe
Have you tried a torch?
Old Aug 3, 2017 | 05:48 AM
Re: Front subframe
I haven't yet just tried gonna try this weekend
