I'm putting a C4 front suspension into my trans am!!
Old Feb 25, 2018 | 01:16 AM
  #151
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Re: I'm putting a C4 front suspension into my trans am!!
Steering rack and lower A-arms in for good! Overall fit is excellent. Great clearance everywhere and the rack measures out perfectly level with the ground, just like the lower control arm mounts. Everything is shaping up perfect!
Attached Thumbnails I'm putting a C4 front suspension into my trans am!!-dsc02716.jpg   I'm putting a C4 front suspension into my trans am!!-dsc02717.jpg   I'm putting a C4 front suspension into my trans am!!-dsc02720.jpg
Old Feb 25, 2018 | 04:44 AM
  #152
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
so how long before the test drive happens!!!!!!
Old Feb 25, 2018 | 07:25 PM
  #153
Car: 1986 Trans am
Engine: 5.3 LM7
Upper A-arms now installed permanently with fresh bushings and ball joints, pass side turbo manifold back on along with plug wires and dipstick, and found that a 4th gen power steering line fits like it was made for the car...who woulda thought lol.
If all goes according to plan...I'm staying hopeful that it'll be road worthy in a few weeks.
Attached Thumbnails I'm putting a C4 front suspension into my trans am!!-dsc02723.jpg   I'm putting a C4 front suspension into my trans am!!-dsc02724.jpg   I'm putting a C4 front suspension into my trans am!!-dsc02726.jpg
Old Feb 26, 2018 | 07:11 AM
  #154
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Leave the strut holes open, that will screw with anyone who does a quick look under there, that knows these cars, lol
Old Feb 26, 2018 | 10:39 PM
  #155
Car: 1986 Trans am
Engine: 5.3 LM7
New vid
LOL, I would but the tops of my strut towers are ugly and beat to heck from the caster camber plates...better to just cover the ugliness up!
Old Feb 27, 2018 | 08:13 AM
  #156
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Put in a broken stock mount with the strut coming through it then
Old Feb 27, 2018 | 12:17 PM
  #157
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
this x1000!
'I thought I heard a clunk on the way to the show'
Old Mar 2, 2018 | 07:58 PM
  #158
Car: 1986 Trans am
Engine: 5.3 LM7
I want this info to be out there on the web because it just gave me a massive migraine trying to figure it out, and every forum I searched on had questions but no answers... Regarding bump steer kits on the corvette suspension, the corvette uses the same 1.5" per foot (listed as GM 10*) taper that every other GM vehicle uses. However, because the corvette spindles are aluminum, GM apparently sunk the taper in a bit deeper. For this reason, many aftermarket GM bump steer kits do not fully seat because they hit the integrated nut on the bump steer stud before the taper gets all the way in. My solution was to grind off the integrated nut on a bench grinder and follow the existing taper, essentially extending the tapered part of the bump steer stud. It now fully seats in the corvette spindle and fits like a glove, the way it should. Just have to add a second washer on the top side to compensate for the small end of the taper slightly protruding through. I'm also using a spohn bump steer kit for a 4th gen F-body, for reference.
Attached Thumbnails I'm putting a C4 front suspension into my trans am!!-dsc02735.jpg   I'm putting a C4 front suspension into my trans am!!-dsc02736.jpg   I'm putting a C4 front suspension into my trans am!!-dsc02738.jpg
Old Mar 3, 2018 | 01:12 AM
  #159
SlickTrackGod's Avatar
On Probation
Just a useful note: It is perfectly acceptable to just drill out the spindle to 5/8" and use grade8 bolts with 5/8" rod ends and spacers on the bolt. Makes life much easier in any GM application. You do not necessarily need to use a taper.
Project is coming along great (thumbs up)
Old Mar 3, 2018 | 08:23 AM
  #160
Car: 1986 Trans am
Engine: 5.3 LM7
The standard bolt was an option that almost followed through during my head scratching, while trying to figure out the taper issue. I've always had a slight preference to a taper fit only because they eliminate any chance of play by design. But regardless, I'm glad this problem is behind me now!
And thanks, I'm getting extremely excited to start testing things out. Hopefully within a few weeks.
Old Mar 3, 2018 | 08:38 AM
  #161
On Probation
Yes the taper IS in fact a safer design due to it "cinching" into place and the cotter pin. When you do a bolt I like to use one without a shoulder so I can run a washer and locknut all the way up under the spindle arm so as to permanently lock it into position- then run the spacers and rodend up against it and lucknut on the bottom. Your Meziere flared safety misalignment spacers are a piece of mind and a smart choice in a single shear application like that in case of ever a rodend failure it keeps everything together. I use them on my Mercedes rear suspension links I have in single shear.
Old Mar 14, 2018 | 09:24 PM
  #162
Car: 1986 Trans am
Engine: 5.3 LM7
New vid Car is literally 3 parts away from being drivable!
Old Mar 31, 2018 | 07:14 PM
  #163
Car: 1986 Trans am
Engine: 5.3 LM7
Gentlemen... test drive footage
The car feels transformed. I honestly don't even feel like I'm driving a 3rd gen. Steering is amazing - crisp, tight...no bumpsteer whatsoever. The ride is amazing, everything is amazing! I drove it probably 40+ miles today and I'm falling in love with the car all over again. It literally steers and feels like a modern sports car. The one thing I need to change is my wheel backspacing in front to get rid of the excessive scrub radius, but even that is not generally noticeable most of the time while driving. I am LOVING it!!!!
Old Mar 31, 2018 | 08:51 PM
  #164
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Congratulations! I"m glad all of the hard work paid off.
Old Mar 31, 2018 | 09:26 PM
  #165
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
congrats. nice job
Old Apr 19, 2018 | 06:52 PM
  #166
Tex WS6's Avatar
White Devil TA
Cain't Say enough good about your talent, your build and your presentation. Enjoy a great car.
Having done one, if you were to build another would you do anything different?
Tex
Old Apr 20, 2018 | 05:35 AM
  #167
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Congrats man!
I wish I had the skill and courage to do something similar to my car!
Old Jan 1, 2019 | 10:16 PM
  #168
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
Somehow your video showed up in my youtube feed, glad I saw it. I've wondered about racks going into our cars, though the lack of success generally kept me from looking into it, the only 'bolt in' options being drag only. Glad it worked out for you, any further follow up comments after driving it over the summer?
I'd love to do exactly what you did, but a small single car garage and no fab skills will make it hard
On a side note, how hard is it to not just light up the rears with the turbo, or are you just running drag radials?
Old Jan 6, 2019 | 09:59 PM
  #169
On Probation
I see he has not answered after giving it a few days. He and I ended up conversing a lot on this and I did my best to help him with his desire. In the end he was happy with the overall outcome and I commend his fabricating skills and effort- His desire was to just have a decent cruiser and that he is happy enough with.
With that said, he did admit to me the car does want to yank the steering wheel under heavy braking on uneven surfaces just as I warned him this would do in my first post prior to him ever starting this project. For him? not a bad thing, he is content, but put that car on a track and he will have a handful under high speed braking. No bashing, just posting facts and actual final conversations he and I had about the outcome.
Dean
ps- only so much you can do with a specific tack width marrying it to another platform.
Old Jan 7, 2019 | 11:44 AM
  #170
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Why is that?
Old Jan 8, 2019 | 09:04 PM
  #171
On Probation
Why is that?
I explained it in detail on page 1.
Edt to add- my very first couple of posts , before this project even started.
Old Jan 9, 2019 | 10:08 AM
  #172
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Thanks, I went back and read now. Honestly, I forgot you commented early on in the thread.
Old Jan 10, 2019 | 02:18 PM
  #173
V6canvas's Avatar
Engine: Stock LS1
Dean
Thanks for the reply, I had been 'hoping' that it wouldn't be a handful on track. While I don't often go to the track, I don't want to limit myself either. Also, there are times where you have to hit the brakes hard due to traffic/idiots/deer whatever on the street from possible highway speeds, so even if it's a street only car, still something to keep in mind. Being in Michigan, if a road is smooth now, give it a year or 2, tops, and you'll have all the uneven road you desire.
For those who like re-engineering cars and great fab work, I'd recommend looking up Project Binky on youtube. I haven't gone through the entire series yet, but the work they've done on the car is amazing.
Old Mar 1, 2019 | 04:12 PM
  #174
Car: 1986 Trans am
Engine: 5.3 LM7
Sorry I haven't been on to reply. I don't visit TGO nearly as much as I used to. To answer any questions regarding the overall outcome and steering/braking feel, I am honestly in love with the front suspension. I have been tweaking it here and there as far as alignment specs, and ended up getting front wheels with a different offset to improve my scrub radius numbers. The wheels made a huge difference in reducing steering effort, and now during low speed turns, it has a firm sporty feel, but nowhere near "too" stiff.
As for braking, the car felt slightly unstable ONLY during braking while cornering. However, I noticed shortly after that I mistakenly set the alignment with way too much toe in (roughly 1/4" but it was purely by accident). When I finally noticed my mistake, I readjusted the toe to about 1/16" toe out and the stability during hard cornering braking feels excellent now.
Bump steer is virtually non existent, and I have had the car down some horrendous back roads filled with bumps and uneven road surfaces. At this point, I have about 1200 miles on the suspension and the car is a dream to drive vs the old factory style setup. In a racing environment, you may find issues since obviously this setup was designed around another chassis' geometry, but for my purpose of this car being 99% street driven, I am absolutely in love with the feel and wouldn't take it back for a second. It's amazing to be able to drive down backroads with a big 275 front tire and have the steering feel completely tight with no wander at all. And to be honest, in my opinion this suspension actually rides smoother than my particular stock style setup. It absorbs bumps amazingly well!
Old Mar 4, 2019 | 02:27 PM
  #175
V6canvas's Avatar
Engine: Stock LS1
Glad to hear you got it sorted out, that toe in will really make a difference! Any idea if the Hawks reproduction lace wheels are close to the right offset (at least compared to what you ended up with)?
Old Mar 4, 2019 | 09:40 PM
  #176
ughmas's Avatar
Car: '90 Formula '88 GTA
Engine: 305 TPI 350 TPI
Transmission: T5 700R4
Axle/Gears: 3.42 10 Bolt 3.27 9 bolt
Awesome thread and build! Glad it turned out well for you - I thought I had learned a lot in recent years but the conversation here just made me feel like a 10 year old when it comes to suspension set up :/
Old Mar 26, 2019 | 04:59 PM
  #177
Car: 1986 Trans am
Engine: 5.3 LM7
Honestly no idea on the hawks wheels, but I'm assuming they are a 3rd gen type of offset which will probably be way off. The front wheels I'm running with this setup are 17x9 with a 6.1" backspace I believe. They are very close to 4th gen front wheels if I'm not mistaken.
Thank you! Honestly, I learned a TON of new info during this project as far as suspension geometry goes. I thought I was pretty knowledgeable before, but once you dive into custom suspension, it's a whole new world!
Old Mar 27, 2019 | 12:15 PM
  #178
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44 IRS, Tru Trac, 3:73 gears
It's great to hear you have everything sorted out. Looking forward to getting mine on the road.
