Bad Centerlink?
Old Sep 29, 2017 | 09:49 AM
Blaze of Glory's Avatar
Car: 92 Firebird
Engine: 3.1L V6
Bad Centerlink?
I replaced all the steering components about two years ago. Lately, the steering has felt abnormally loose.
With the car parked and running I had someone move the steering wheel back and forth while I watched the joints. I could see the pitman arm move about a 1/4” before the center link would move. Is this normal?
Old Sep 29, 2017 | 01:55 PM
Re: Bad Centerlink?
Yes that is "normal": for a failed center link. It's Abby Someone for a functional one however.
Old Sep 29, 2017 | 04:28 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Bad Centerlink?
Raise your hand if you got that reference!
Old Sep 29, 2017 | 05:10 PM
Car: 92 Firebird
Engine: 3.1L V6
Re: Bad Centerlink?
*keep hands lowered*
Old Sep 29, 2017 | 05:29 PM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
Re: Bad Centerlink?
Good idea to check the idler arm as well. If you can move it 1/8" out more at the center link end with about 25lbs force replace it....
Old Sep 30, 2017 | 10:39 AM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: Bad Centerlink?
