Manual steering box help
Old Oct 24, 2017 | 09:33 PM
91rsdragcar's Avatar
Changing from power steering to manual. I'm using the Camaro pitman arm
Which is the correct direction of the pitman arm when box is centered ?
Old Oct 25, 2017 | 06:33 AM
Re: Manual steering box help
Straight front to rear w/ gearbox & steering wheel set to exact center
Tie rods should be pretty close to equal length with the wheels pointed straight ahead
Idler arm should also be straight front to rear
Old Oct 25, 2017 | 11:32 AM
Thank you
Old Aug 9, 2018 | 10:55 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Sorry to bring up an old thread, but I just installed the s10 manual box. No my steering wheel is 90 degrees to the left, and my passenger tire is sticking out, while the drivers tire is straight?
What do I need to adjust to correct this?
Old Aug 9, 2018 | 12:43 PM
Drew's Avatar
An alignment.
Old Aug 9, 2018 | 06:17 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Ok, fixed the steering wheel, it's straight now.
But the passenger wheel is out slightly.
Is it normal for everyone that did the manual box swap, to get an alignment?
